I have the 6x9's wired straight from the head unit back. and the reason i used 6x9's there is simply because i had them sitting around being unused.Rex wrote:I agree either work the rest of the interiors color scheme (cloth seat color) into the box or leave it red to match the exterior, but use some vinyl.
How do you have the 6x9's wired?
Personally, I'm not a fan of anything above a mid from behind the listener, but to each his own, I'm just curious.
ehh maybe but it'd be one tight fit and probably wouldn't sound too good.... that's why i went with a single 12". Are you planning on trying to make something for your car?ccS13_240sx wrote:You think you could do that same set up but with 2 tens?
The amp is only pushing the sub. I'm working on getting an amp for my highs. And i made it so that i can still get to the spare tire. The only rattles were the plastic right above the seatbelt pulley. Also the lights right above the license plate fell but that's mainly because of rust it was only a matter of time before they gave. thanks for the comments.BlackHat wrote:Pretty nice. Looks like a clean install. I was trying to figure out a way to point my subs back too. Ended up just saying screw it. It's really not a big enough area to worry about it.
Is the amp just for the sub? Or are you driving the 4x6"s with one too? Did you just toss the spare tire or can you still get to it somehow?
And just so I can maybe catch something before my system is up, did you find any problem rattles that you had to dampen?
You gave me some ideas with how to handle the bare metal along the sides in the trunk area. I think custom fiberglass would probably be my route on the back though... maybe make a little housing for a battery relocation.
Great job!
False information alert!!!amolao wrote:.use two 10's instead of a single 12', it will give you a sharper bass...
x2........PoorManQ45 wrote:huh?
i dunno...lame joke. anyway, i have a coupe so i can fit like 1 ten in there without sacrificing the usability of my trunk. so i went with an alpine type-r, "custom" built box by me (looks bad, but works), and a sony xplod 1200 watt amp. i also gots 3 way 4x6 pioneers in the front and 3 way 6.5 ecplises in the back. yuumers.PoorManQ45 wrote: huh?
