My beautiful 300 needs help
nathanmoris
Car: 1992 300zx
I dont know whats going on but here goes... my car was running fine then all of a sudden one morning i went to start it and it made this grind nosie and i wouldnt turn over... like it seized.. i went to hand crank the motor to see if that was the case but the motor turned. I went to try to start it again and it started up fine.. turned it on and off again through out the day (not diving it tho) and once again it happened like after ten or so times later... i hand cranked the motor for a few mins and sometimes through out the cranking it seems to get a little hard then litghtens up but no seizing.. Does anybody know whats going on... thanks
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
Sounds like your starter is going out. Replace that and it should go away.
