slw240sx »
https://forums.nicoclub.com/slw240sx-u528.html
Thu Apr 03, 2003 12:32 am
ok, well my beater is my auto matic 1990 sohc. fastback with 171000 on its been running good lately, but yester day i was working filled up my tank and les then ten mins later it starts missfiring , backfiring shaking, sputtering dying on me... revd it up real high it went away for 10miles then kicked back in! now i ve changed the plugs dist roto button. took out all injectors cleaned each in alcohol.... well before that all plugs looked burn except that #3 had crap on it and was soaking wet with fuel1!! well after the injector cleaning its dry but the motor still isnt running.. itll turn over shake fire intermittely n die out .... could it be bad gas.. i used 87 from some rinky dink station !! could it been the bottom of the tank and varnish? i put in to bottles of iso heet to cure water problem but no differance ... tomorow the filter is changing and the fuel injector cleaner goes in then onto the pump!! what else could it be.. headgasket... but not smoking at all no coolant in oil could have oil in coolant but it was pretty rusty to start with so rust colored coolant ???
