My battery is in my trunk...
KimberlyS13
Car: 1990 Nissan 240SX
I haven't had any issues as of yet with my battery in my hatch.. but I want to secure it somehow. Right now it is just sitting back there and is in need of a little tlc. Does anyone else have their battery in the hatch that would be willing to share pics or ideas?Thanks much!
oh btw, if anyone remembers me from a post a while back my engine fire turned out to be my starter shorting out.. only a $385 fix, nothing else was ruined BUT then 3 days after having it out of the shop 2 of my fuel injectors died.. dont worry I have 4 Venom fuel injectors on the way... trying to find pink covers for them however....
-Kim
s13point5
Car: 89 240sx
autozone has a battery box for 12 bucks that i used. 4 screws into the body of the car in the trunk and its mounted securely
PorkChopExpress
Car: rb kouki
:I used the same one. Not flashy but gets the job done.
onosqv
Car: '92 240sx Vert
using stock battery or a sealed battery (i.e. optima, etc)?
Stock battery, you need to go w/ full enclosure w/ proper way of venting the fumes from battery out of the car, else bad things will happen.
optima style battery, you can use all sorts of fancy smancy holders - you can search for my diy relocation thread, shows the mount I used... actually, why not, here it is:
may be for sale, by the way .
KimberlyS13
Awesome! Thanks so much for the great suggestions!
