Thanks to the FAQ... I know I have a 2001 (not 2001.5) Nissan Pathfinder LE with less than 50k miles.
It has the Bose 6 CD changer.
I love my Pathfinder. However, I've been trying to figure out why over the last couple of years my battery keeps getting drained when I don't drive my vehicle for a few days. I have more than one vehicle to drive so it doesn't get used very week. I've replaced the battery twice because of this and the last time was less than a year ago. I'm having NO other electrical issues with the car other than the stereo acting wonky on occasion. I've had it forget the presets, spit the CDs out even when I was only using the radio.
In doing some research online, I've seen where some people are posting about the Bose system having "issues" and could be causing battery drain. So, in my attempt to isolate the culprit, I took out the fuse #15 (which looked perfectly fine) and intentionally didn't drive it for a week. 7 days later, it started up with no problems. I've only been able to leave it sit for about 3 days before.
In doing some digging online and here, I've found these (links below). I have no idea if they pertain to my issue or not but I thought I'd show you what I have been reading.
Link to a thread on Here - Radio Issues
(hoping someone can tell me if the comments/link by qx4radioissue could be applicable)
All Experts Question Link
G35 Battery Drain Link
My goal:
I'm not as concerned about having a CD player as much as a radio.
Is there a way I can make the radio portion of my existing Bose system work so I don't have to get an aftermarket system?
Can I replace the circuit board (mentioned in the link above), keep my system and just remember to never turn the engine off without first turning off the radio?
Would this truly prevent the battery drain?
Is it possible it's the amplifier and not the Bose system? If so, what would isolate it as the problem, where exactly IS it in the vehicle and can I replace just this component? Would it have to be a Bose duplicate?
I hope one of the above is possible because I'm reading where making an aftermarket system work is a whole different can of worms to open.
Many thanks in advance to those who read and provide replies.
