S14tat wrote:so you would never recommend the greddy kit to anyone? i'm kinda disapointed becasue they make excellent honda kits. oh wellz. how much power do you think your making?
I have run into so many issues that are going to need addressed...
I'll list them out.
1: The Greddy Mani is hard to install. You cant torque it down right and a short 14mm is needed for the bottom 3 nuts due to the Manifold blocking access.
2: The wastegate does not let upgrade your exhaust. Its to small to flow correctly... If I had a built engine and larger injectors it would be fine I guess.
3: The intercooler piping rubs on the small power steering line (mine wore through it) it also hits the AC stuff and wore through the plastic cap on the discharge nipple. The 1st bend is almost rubbed through the pipe due to the power steering. The second pipe is rubbing on the body because the engine movement... So that's going to blow out soon. The left side of the pipes seem to be doing fine...
4: The E-Manage is a ***** to tune... I am starting to get my AFR's in order again but it takes forever unless you hit the dyno.
I did pull some timing... WD posted you don't need to back off timing before 8psi so I took all my timing out of 6psi and did -2 at 7 and -4 at 8 -6 above 8... The car scoots allot faster... ( I need something to read my total timing...)
I think I was near 120k when I did mine... And I use to red line it all the time... Now I'm close to 140k I think... so almost 20k on the kit... And now I can redline more!
EDIT: ohh and my 1st dyno I got like 193hp out of 8psi with a poor tune... That will almost make you cry after spending 2900 on the kit 1200 exhaust and 700 intercooler... and 500 for the Profec E-01...
