Lokim »
https://forums.nicoclub.com/lokim-u160520.html
Mon Mar 14, 2011 12:21 pm
Well, the rack's end seals were blown out, so I was basically performing a perpetual P/S flush. When I swapped out the rack, I cycled the new rack back and forth several times to pump out the test fluid they always come filled with and allowed the reservoir and pump to drain via the pressure and return lines. After installation and verifying all fittings were tight I filled the system with Amsoil ATF. It took just shy of a quart.
