OguraPowerTuning wrote:http://www.allnissans.com/showthread.php?t=2451above is a link to a b12 chassis forum i post on. im building up my b12 and installing a ca18det. the motor im using i took out of my s13. it ran perfectly in the s13 and made good power. i know for this project ill need an 88 pulsar parts car for the transmission and im assuming i need the axels. my question is(boostboy please respond) do i just use the 88 pulsar wiring harness and plug in the ecu from my s13? or, boostboy, do you have somekind of hybrid harness i would need to use? if so i would like to buy whatever i need from you to get running, since it seems like you sell ca stuff and run a shop or something. dee, you are the king of the CAb12 so any help would be greatly appreciated .jason
I have an AWD harness in my garage somewhere, that needs a bit of repairing. With this harness, you can use your S13 (CA) ecu. Back in the day (late 96 early 97), I used a complete pulsar engine and ecu harness on my B12, paid Jim Wolf Technology good money to remap the pulsar's ecu, had problems with it because they had never done one before, and they finally got it right and the car was pretty bad for what it was. But I definitely don't use that stuff anymore because I need to be able to make adjustments on the fly and on the dynomometer. If you are interested in this harness, I'll have to make repairs on the ecu blue plug because it got cracked during shipping. What is your power goals? Let me know and I can probably help you on the what not to do's as well.
Dee
