BearTrap »
https://forums.nicoclub.com/beartrap-u103945.html
Thu Sep 11, 2008 7:56 am
I’m trying to pass emissions here in AZ, and here’s my setup:1990 240KA24E – rebuilt 20k miles ago (passed MO emissions at the time) - running 92 octane on about 9.75-10:1 compression- bored cylinders with 90mm pistons- shaved deck- .402/270 degree performance cam- Port/polished head- 550cc(?) injectors- Walbro fuel pump- MSD ignition/coil/wires- Injen intake- Etc….
Preliminary check of systems: Good spark to decent plugs (a little burnt; but not bad), original cat (I know). Cause of the cam it’s rollin hard at idle, little accelerator hesitation at low rpms, kinda fumey when running still; but not smoking. Other than that, it’s running like a bat outta hell.
My emissions report here in AZ in grams/mile:
My car vs AllowedHydrocarbons 2.56 1.00Carbon Mono 70.11 12.00Nitrogen Oxides 1.38 2.50
Since the test,Plugs – Old ones were a bit burnt; but nothing too bad. ReplacedO2 Sensor – I’ve never seen one before; but it looked alright? It was light brown; but not black/carboned or damaged. ReplacedWater Temp Sensor – ReplacedCatalytic Converter – I don’t want to replace it yet. I’ve read that the cat can help if I’m close; but if I’m waaaaayyyyy over, it might actually make it worse.
What do you guys think? I’ve been thinking the cam/fuel setup could just be shoving in too much gas; but, if I have good spark/timing/compression what’s the problem? I know with a cam has low vacuum/high fuel volume at low rpm; but would I not be burning all of it? If I’m not burning all the gas, wouldn’t my plugs and o2 sensor look crazy black, burnt, or sludgy? All four plugs were uniformly light brown and were sending a good* spark when tested.
Thanks for any advice. I love my car and would hate to have to put it in storage till I get a house….No plate = No drive and no park
