My auto transmission surprised me tonight..
4felix20
Car: Emerald Blue S14
On the drive home, there are so many bad drivers. You all know what I'm talking about. People driving way too slow, changing lanes right in front of you, then going obnoxiously slow. :mad: I'm ready to get home! Finally, my slow asss wolf pack slows to a red light. There's an extra lane with no cars up yet. Whipped over there and waited for the green...gave her a good swallow of high octane and quick as shiit I chirp away from those idiots, but then! as I near the second automatic transmission gear, I kinda let off the gas a little to quicken the shifting, then give her another good gulp. Chirped the wheels again!!
My automatic transmission peeled a wheel as it changed gears. LoL I've never done that with out a good 5 speed...:icon18
Do you guys know what I'm talking about? I can't wait to get my turbo.
toki
Survey sais:
BAD TIRES
maxpower
Car: WRX
that's amaizing. are you going to turblow the KA and keep the automagic ?
My clutch disc is so worn i can't get wheelspin going into second anymore. rear tyres are @42psi with some tread.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
ITS NOT THE TIRES, MY AUTO DOES IT AND I HAVE BRAND NEW TIRES. IF YOU WANT A HARD SHIFTING AUTO UNPLUG THE RPM RESISTOR, THEN IT'LL FEEL LIKE THE REAR IS SQUATING AND THEN THERE IS A BOOST OF SPEED BETWEEN 1 AND 2 AND A SLIGHT CHIRP.
maxpower
Car: WRX
musicsurfman wrote:ITS NOT THE TIRES, MY AUTO DOES IT AND I HAVE BRAND NEW TIRES. IF YOU WANT A HARD SHIFTING AUTO UNPLUG THE RPM RESISTOR, THEN IT'LL FEEL LIKE THE REAR IS SQUATING AND THEN THERE IS A BOOST OF SPEED BETWEEN 1 AND 2 AND A SLIGHT CHIRP.
PROJECTRB240SX
WOULD YOU LIKE ME TO PROVE IT TO YOU? I'LL EVEN LET YOU DRIVE IT! ITS NOT A REAL BOOST OF SPEED ITS JUST THE CAR LIFTING THEN SQUATING BACK DOWN. YOUR JUST ANOTHER ONE OF THOSE MINDLESS 5 SPD IS BETTER IDIOTS WHO DON'T KNOW THAT AUTO RULE THE DRAG STRIP. AUTOS ARE BETTER FOR STRAIGHT LINE MANUALS ARE BETTER FOR ROAD COURSES AND OTHER MULTI-DIRECTIONAL GEAR CHANGING SITUATIONS.
nissanrcer240
Car: 90 Nissan 240SX SR20DET
im not takin sides here, but when i had my auto 240 i would occasionaly chirp second gear while excelerating hard too
s14a
Car: 98 240 white
DONT unplug the resistor, i did it and got a check engine light the next day. Also you can burn out your transmission fluid w/o the resistor plugged in.
sammy
Car: cars, guns, music......the usual guy stuff
my ragged out 89 hatch has an auto, and I noticed MAJOR better shifts (and second gear chirps) after unplugging the resistor...........damn near gave my g/f whiplash......so the resistor is plugged back in now to keep her off my azz......also, I noticed the trannie would not downshift when I turned O/D off when it was unplugged........it just seemed to freewheel sort of......
nissanrcer240
i didnt have my resistor unplugged when i did it
PROJECTRB240SX
YEAH THE UNPLUG IS FOR HARD SHIFTS. IT STOPS THE ECU FROM SENSING ROTATION AND DOESN'T ALLOW THE transmission TO SLOW BEFORE SHIFTING AND SLAMS THE GEAR. THE CHECK ENGINE LIGHT HAS NOTHING TO DO WITH IT BECAUSE THE CIRCUIT ISN'T MONITORED, IT IS JUST A COMFORT SENSOR. THE FLUID IN MY transmission IS DRAINED CONSISTENTLY EVERY OIL CHANGE CAUSE I'M A HARD DRIVER. YOU CAN CHRIP THE TIRES WITHOUT THE UNPLUG BUT IF YOU WANT A PERFORMANCE FEEL AND ABOUT A .1 TO .3 FASTER ET, UNPLUG IT FOR FUN AND SEE THE DIFFERENCE. I CAN VOUCH FOR THIS METHOD AS I HAVE HAD IT THIS WAY EVER SINCE I BOUGHT THE CAR.
MAXPOWER THE OFFER IS STILL ON THE TABLE YOU ARE MORE THAN WELCOME TO COME AND PROVE ME WRONG IF YOU'D LIKE.
SpeedS13
Car: ...
lol ive done this in a damn 89 accord i beat the **** out of it.. if you really wanna feel like a bad *** and squeel em do a nutral(throw it into nutral stomp the gas slide it back down to 2 ) just hope nothin starts to fall out the bottom end afterwards, i dont recomend it unless your beatin the **** out of the car.
red240ne
Car: mmm...donuts
bah, i tried it on my old beater 240. It doesn't do jack schnit. It's all in your head. It makes the car run like crap, that's about it.
Nathan
I had a 90' Camry...it would smoke the tire easily if I revved to 6,000 then shifted to drive :) It also worked well to accelerate backwards at about 10mph then shift into drive while standing on the gas...nice big white cloud.
Altiman94
Car: 1989 Nissan 240SX
Automatics are only good for drag racing with forced induction applications, and even tho, no one would use a stock automatic transmission. With a shift kit, an automatic can run good times, but I would rather have controll of my engine's rpms manually.
4felix20
bad tires my asss! that's good ole 2.4 liter TORQUE! snapped my head back into the headrest...
once my auto loses it's magic, i'd like to swap the trannys if i can find a 240 in good shape at the junk yard. i love manuals and wish i had one but for some reason, it seems like 80% of all 240s were all automatics or something. wtf.
i wonder if there are any buildups for the automatics..?
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
I have done the exact same thing in my '95 when it was an auto. I floored it, let go of the gas right before it would shift, then peg it down again and it would chirp 2nd HARD. It scaired the piss outa my friend.
4felix20
:) i read a little of your thread about the problems with your swap. did your work out any of the kinks before it got wrecked? was it worth it?
red240ne
Car: mmm...donuts
I can easily smoke the tires in my mom's auto 2001 Maxima. My mom even did it on accident once.:)
WingsNThangs
Car: 91 240SX
toki wrote:Survey sais:
BAD TIRES
Really? I thought it was easier to chirp with new tires.
