My audio, climate control dont work!!!! what do i do i need help!!!!!
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
DEEPSSM
Car: Infiniti G35 Sedan
I need help, my stock bose stereo doesnt work and my a/c doesnt work and i cant control it either. Have any of u guys know a solution please help me!!!!!!!!!! Thanks.
CrackaLackin
Car: 2005 G35 Sedan 3.5L Lakeshore Slate/Um... the tan/grey one
Does it not power up at all? as in you push the buttons and nothing happens?
smockers83
Car: 2006 G35 Coupe
Let me guess, you have an 03 or 04 model? This is a known issue. You can either have the dealership take care of it or one of the site sponsors, forget which one, repairs this as well.
Or maybe it's time to upgrade that stereo! That's what I would do if that happened to mine, it would give me a reason to get going on my stereo plans.
It's Infiniti by the way
Welcome to NICO!
joe603
Car: 2014 Durango R/T
smockers83 wrote:Let me guess, you have an 03 or 04 model? This is a known issue. You can either have the dealership take care of it or one of the site sponsors, forget which one, repairs this as well.
Welcome to NICO!
+1
These guys will fix your OEM deck... http://www.shortcircuitrepair.com/
DEEPSSM
thanks you rock!!!
DEEPSSM
nothin happens i push and push
titanium681
Car: 2004 g35
I've got similar issues with my CD player on my 04 g35. Was there ever a recall issued by Infiniti, since it's so common? Who makes an aftermarket replacement that fit in the stock location?
joe603
If you go aftermarket, you have to buy a few things to make it work. 1st the trim and bracket need to be changed to fit a double din deck. If you want a singe din, then another adapter will need to be added. 2nd, you have to replace the AC controller board. Everything all said and done will cost around $300...then you need the actual head deck.
Check out these guys: http://www.grubbsperformance.c...Front
g35sedanlover
Car: 03 Infiniti G35 Sedan
If you end up replacing the switch board for the AC/radio, can I have your old one? I would like to do some experimenting in an attempt to make my own double din kit.
Return to “G35 and G37 Interior, Exterior and Audio”
