so i decided that i will attempt to make another one out of some scrap square tubing i had laying around. lol
first my dad welded two pieces of 1/2 inch by 1/2 tubing together.
then i bent the two welded together tubes until they matched up to the bolts and cleared the top of my engine.
i then had to bend and make sure its actually level. (to the ground not necessarily to the engine lol)
then i bought some pipes and screws that fit tight in them, and welded those onto the ends of the newly made strutbar.
it was then i decided i might as well make braces to triangulate to the radiator support since i have leftover materials haha.
so i made brackets to bolt into one of the same locations of the pop up headlights on each side and welded them to a piece of the pipe. then welded the pipe to the strut bar and called it a night haha
I'll finish up all the welds, clean, and maybe primer tommorow after school and put some better pics up. :p
