my antenna makes noise on 95 maxima
nissanmax51
Car: 95 nissan maxima GLE
Hi I'm new and i have a 95 maxima and sometimes the antenna makes a grinding sound when it goes in so i was wondering is there a special kind of grease i can put on it so it won't make that noise anymore. THANKS.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Try some white lithium grease.
ZGadson
nissanmax51 wrote:Hi I'm new and i have a 95 maxima and sometimes the antenna makes a grinding sound when it goes in so i was wondering is there a special kind of grease i can put on it so it won't make that noise anymore. THANKS.
Grinding = Gears are shot. There is a notched out piece of plastic that goes inside the entire length of the antenna. In the gearbox (curcular thing at the bottom of the antanna inside the trunk) with a gear that pushes the notched plastic wire upwards. If the plastic part or the gear in the base is broken, it will grind.
