redmanfx wrote:Just add 3 ounces of acetone per 10 gallons of gas!! Simple.... OH and the government is wrong--- Acetone does not evaporate from gasoline!!!!!! So why hasn't there been a push for this addition of acetone in gas from producers????
Good Question.. I suggest research because you'll be blown away. Here is just a scratch..http://www.pureenergysystems.c...etone/Did you know that research on this has been covered up? Serious, it has.
It's already in gas cleaners. What say you chemist out there?
Isn't acetone harmful to rubber and plastics? How would the injectors react to it? Maybe initially, it won't do too much harm, but over time, I think the fuel lines will be eaten away or suffer some sort of damage.
http://www.digg.com/mods/Aceto...leage
I'm not really much of a complainer about gas and mileage. If I was, I wouldn't drive a Q. Only 92 or higher goes in it. I also live in Jersey. Cheap gas, and I don't have to pump it.
If gas prices are really affecting your way of living, it's either time to get a more "fuel-efficient" car or ask for that raise.
These cars were built to compete with Mercedes-Benz and BMW V8 sedans. You wouldn't toss acetone and apint thinner into their tanks. Why treat the Q any different? Because it's a Nissan?
I think methods like acetone and other solvents to improve mileage and fuel effiency are more harmful to an older vehicle like a VH45DE equipped Q and are more suited to the newer engine designs. I don't think the Engineer-Sans at Nissan envisioned gas prices going this high when designing this engine.
