My Altima> your Altima
twelv
Car: Nissan Maxima
Post one pic and a list of your mods and show every one how bad your Altima is.
Simmsled
Car: TSI GTI - E46 325i
Intake: Weapon R short ramHeader: OBX 4/2/1 Cat: ZERO, ZILCH, NADAExhaust: Greddy SP1 cat-backSprings: Intrax lowering springsStruts: KYB GR2Control Arm Energy Suspension Poly Bushings (Maxima kit... pain in the arse)Front Swaybar: Energy Suspension end linksRear Swaybar: Suspension Techniques swaybar w/poly bushingsBrakes: Motul badass fluid, Perfromance Friction Carbon Metallic pads WITH REAR DRUM BRAKES!!!Wheels: 18x7 VOXX MGR 42mm offsetTires: 225/40-18 Kuhmo Ecsta Supra 712
Stereo: Too much to list, if you care check out the Car Audio Forum and look it up. BUT IT HAS MADDD SICKK ICE!!!!!!!
CHECK OUT MY BLURRY PIC!!!
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Matt,Where was that picture taken at? It doesnt look familiar.
Cold_Zero
http://nissaninfiniticlub.net/...t=500
Only mods I have are wheels and a hot female driver.bud
twelv
Car: Nissan Maxima
Exterior:Active Tuning lux grill Black Oval MeshActive Tuning Super Black (KH3) S2 grill Black Oval Mesh Two Tone paint job Super Black (KH3) and Sheer Silver (KY1) (All OEM nissan Colors)Blacked out Headlights with clear reflectorsLower Tech grille Black circle meshCarolinanissans.com DecalsUndivided Attention BannerDebadged Trunk of OEM badgesRebadged Trunk with Custom letters left side TWELV <---NicknameRebadged Trunk with Custom letters right side VQ35DE <---Engine Code31% tintCustom "12" 3rd brake lightOEM side sillsSilverstar 9006 bulbs headlights Silverstar 9005 bulbs fog lightsClear when off/Orange when on bulb for cleared turn signalsStillen Front Lip
Performance: Stock= 195fwhp / modded= 225fwhp
CustomAltima.com Downpipe/RacepipeInjen polished Cold Air IntakeCustom Cat-back: Two Magnaflow Mufflers 14829 2.25 inch Y pipe painted black for stealth2.5 inch straight pipe No Resonator
Engine Bay:
Southwest Autoworks Polished Battery tie downPainted two tone engine cover (same color as car)
Interior:
Rubber Altima all weather floor matsRed bulbs for Door markerRed bulbs for inside Map lightsRed turn signals on dash boardRed Key Ring lightSparco Bio chrome/carbonfiber shifterLeather boot on Auto shifter
Wheels and Suspension:
Eibach Springs: Sportline Lowering Coils-1.8"Front/1.0" RearStillen Rear Sway Bar18" Wheels Gunmetal ENKEI OR52 18 x 8.5 40mm offset235/40/18 Hankook HRII
rey_boricua
Car: Nissan Altima Turbo
Honda Cvic hatchback
T3/T04E (dunno came with the Fmax kit). Tial 35/38 hybrid JWT ECU SAFCII JWT CAMS MSD 72# (with clips) Z32 MAFS Boost Design Fuel Rail Walbro Fuel Pump Aeromotive FPR Pauter Machine Billet Connecting Rod . Stainless Steel and Black Nitrided They are 0.5mm oversized ARP Head and Main Studs Ross 8.5:1CR Forged Pistons are 0.5mm (0.020") oversized Fmax manifold HKS BOV PWR FMIC Fmax DP Custom IC piping Apex-i Turbo Timer Greedy Profec II Boost Controller Autometer Oil Pressure gauge Autometer A/F Autometer Boost gauge Pro Torque coverter
Need things 2.5 Catback soon to be 3inch Need valve body upgrade
Modified by rey_boricua at 11:59 AM 6/22/2005
GregV
Car: 1993 SE-R w/DET, 2003 Altima SE w/mucho
Where to start...
GO FAST PARTSAEM Cold Air IntakeHotshot Headers (with cat)Mossy Performance ExhaustJWT S1 camsJWT aluminum flywheelUR Crank PulleyTechnoSquare ECU
STOP and TURN PARTS2004 Maxima front brakes (12.6")Mossy/Crown Stainless/Kevlar brake lines.Drilled and slotted rear rotorsNismo S-Tune suspension kitStillen rear sway barStillen Front Strut BarStillen/Cusco camber plates
COSMETIC PARTSOEM rear spoilerOEM Side Skirts19x8 OZ Superleggera wheels (gunmetal)255/35/19 Eagle F1 GS-D3 tiresStull front upper and lower billet grillsAll windows tintedTrack tires& wheels: Enkei RP-02 18x9 w/ 275/35/18 Toyo RA-1
260 WHP (before ECU)
twelv
Car: Nissan Maxima
Hey Greg what happend to all the weird graphics on the side of your car.
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
2002 3.5se Black on Black w/ all the factory goodies.Only mods are the grill and hot female driver(stole Bud's Idea for best mod ever)!I'm getting close to getting it paid off and will be able to get a few goodies on it though.
BLAQUE
Car: Nissan Altima
paid off and rusted with that salt water
GregV
twelv wrote:Hey Greg what happend to all the weird graphics on the side of your car.
They came off when I purchased the car.
00_Altima MD
Car: 2004 Sentra SE-R Spec V
power mods:stillen 4:1 header w/ donwpipecustom cat back systeminjen short ram intakenology hot wiresdenso iridium plugszex dry shot of n2o w/ full throttle engagementnx bottle warmer with automatic shut off at 1050 psi
suspension:eibach pro kit springstokico blue shockssuspension techniques rear sway bar
brakes:brembo cross drilled rotors metal masters pads
showhad a set of 17 white 7 spoke rimsnow stock alloys vis carbon fiber hood.
interior:B&M shift knobreverse blue and green indiglow gauges at night and white during the dayblue n2o switch red bottle warmer switch . yes i have the color coded. haha
ben_digt
oki this is my mods
engine interne :
- Ross pistons 0.5mm over 8.5.1- ARP Head and Main Studs - Billet Connecting Rod - 370cc
engine externe
- Turbo DSM big 16g- Costum headers- BOV HKS SSQV- Opgrade fuel pump hi-pressure- 2 slimp fan- Tune ECU- big FMIC(soon in 2 days)- 3" turbo exaust- 2.5" downpipe no cat, high flow- FMU Cartech- Act Stage 3 clutch
Gauges- Boost gauges- Air/Fuel Ratio- Water temp- Voltmetre- oil pressure- shift light
Sound- Head unit JVC- Amp 4 channel power acoustic- Amp mono X5 rockfordforgate- Sub 12" Kicker L7- Ported box 2.5 cubic
Suspension, well and brakes- Brembo disc- Green pad- Drop Gold Line spring- KYB shock - 17' Fast weel- Avid H4 215-45-R17
miss- Side marker- Bleu undercar neon- Silver flame- Bleu neon in car- 4 bleu strob- Wing T2
I think it all!!!!
ultimatuc
Car: fast cars, big trucks, sluts
^^^cool! I'll add another one to the list.
thats pretty cocky of you twelve. I'd love to have the chance to blow your doors off. what time slips do you have?
Turbonetics T0304 ball bearing turbo kitTial 38mm wastegateGreddy profec b spec II boost controllerGreddy turbo timerAutometer boost gaugeJim Wolf Technology ecuJim Wolf Technology camshaftsMax Rev 3.0" down pipe3.0" Extreme Performance catbackJun flywheelACT street/strip clutchPlace Racing polyurithane motor mountsWalbro fuel pump370cc injectorsNismo fuel pressure regulatorAutometer fuel pressure gaugeStillen short throw shifterGreddy oil catch canSWA grounding wires
ultimatuc
my altima > twelves altima
heres a vid of me smoking 2 cars twelve coulnt touch. modded srt4 and modded wrx.
http://roadrunnersauto.com/rick/racevids/brian.WMV
twelv
Car: Nissan Maxima
lol I don't think you can keep up with me now. I am spraying with a 75 shot 325 was the dyno tuning numbers still working out some kinks cause it ran a lil lean last time. Need to buy some more stuff after XMAS damn Holiday took my $1,000 bucks for modding. I don't have a slip but the S2k is a 375whp and my 350Z is 255whp but your car is SUPER FAST. How much faster can you make it?
ultimatuc
twelv wrote: How much faster can you make it?
oh. I can keep up w/ you just fine bro. theres a reason I hold the second fastest slip for an altima ever. and I'm looking to shave a whole second off my time w/ the ems. we'll see.
you should really get out to a track to see how fast she is.
twelv
Car: Nissan Maxima
Lizzy has 13.5 on a 3rd gen with time slips if I am not mistaken and BJ had it in low 13's as well with no BOOST. If you mean first gen prolly so. All I know is that this thing gets like 5 car lengths the only time I tested it on the road against my Z.
I wonder after I work out my lean issue and get a 125 shot installed how more hp will I be pushing. I know my S2K would eat you up wieght ( 2700 with me in it) 375 to rear wheels I can eat an EVO with out giving 100%. I love your car where are you at Miami?
Juaquin
Car: 2003 Altima 3.5L SE with all options/packages, but no mods yet.
yeah, I have to say that even a first gen with boost probably couldn't smoke a 3rd gen 3.5L with light mods. No matter how much more air and fuel you cram in with a turbo, it still wouldn't be enough to match the extra air/fuel from two more cylinders. And just wait till someone figures out how to turbo/supercharge a 3rd gen
ultimatuc
^ Um. there is one 3.5 turbo and I smoked him.
and if twelve is right, there are only 2 third gens that post on altimas.net that are faster than mine.....and they have not posted slips.
ultimatuc
3.5's run 14's w/ i,h,e.
I would like to see what the sers do. please run your car and let us know. I will put money on it that your et cant touch mine.
*edit* sorry, for some reason I thought you had a ser.
Juaquin
You've run against a 3.5L that's turboed? I've heard rumors of one, but I also heard it had a ton of problems. If someone found a reliable way to get it to work that would be awesome.
Yeah, mine isn't a SER, and probably won't ever run faster than a 16 cus it's still under warranty and my dad (who originally bought the car and still techincally owns it) refuses to let me mod it until it's warranty is up. But if I was going to do a project car, it wouldn't be a 3rd gen altima anyway. Altima's are great for everyday driving, they've got plenty of power and looks to turn heads, but they're never gonna run 10's.
Someday I want to get a Z and mod that for drifiting, but that won't be until the far far future, when i actually have the cash to do it.
Simmsled
what do the awd sr20det bluebirds run?
twelv
Car: Nissan Maxima
ultimatuc wrote:^ Um. there is one 3.5 turbo and I smoked him.
The track is 2 hours away and right now all my money is in X mas. When I get a chance I will head up there and see what I can get on a 125 shot. and drag radail tires on my stock 17" rims.
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
Bey, IS your car on steroids?????? wow
Bluebird SSS AttesaAuto- 7.4 seconds for the 0-100km (60mph) and 15.4 seconds over the quarter. manual- 6.2 and 14.5 seconds respectively (remember that's on Japanese grade fuel).
Yes. I am searching for the manual....they are rare...(y u think I was askign how much trouble and money an auto -> manual swap is, autos are errywhere)
accel junky
ben_digt, impressive mod list!
PantherRacer
hey, what's the handling and takeoff on a turboed altima compared to the bluebird sss attesa?
you guys altimas > any altima or bluebird here... at the moment lol
1st Titan
Car: Titan
my wifes stock but the tinted windows5% windows 35% on windshield[IMG][/IMG]
ultimatuc
ultimatuc wrote: I'm looking to shave a whole second off my time w/ the ems..
well guys. I've done just that.
I tuned the EMS and made 300whp and 332 ft lbs.
when I went back to the track I picked up EXACTLY 1 sec and 9 mph.
12.73 @ 110
currently the fastest altima on the net.
95ka24
Car: 1995 Nissan Altima
hey...nice mods...need help here....looking for MOTOR MOUNT- where did you get yours?also, need help to find a aftermarket FUEL RAIL...-95 ALTIMA....-adjustable fuel regulator-AEM cold air intake-customized-cat back exhhaus-irridium plugs/10.3mm wires-oil catch can-coilover kit-strut tower brace-75shot zex-----and working on mounting a R32 taillights-from japan:)-still debating if i should go ALL NATURAL OR BOOST
ultimatuc wrote:^^^cool! I'll add another one to the list.
