marlin29311 »
https://forums.nicoclub.com/marlin29311-u97240.html
Thu May 07, 2009 2:11 am
I'm highly doubting that it was your CVT that was leaking out and causing the smoking...Just because your dipstick has oil on it does not mean that there was oil in the engine...
When is the last time you changed your oil? How was your CVT "acting up?"
There could have also been a problem with the coolant leaking out as well - there are numerous reasons why you could have smoke coming from the engine bay - did you happen to notice if your temp monitor was higher than normal?
You're most likely still under warranty as well, so you should have no issues getting a major problem fixed.
