bimeur »
https://forums.nicoclub.com/bimeur-u78140.html
Tue Mar 27, 2012 2:29 am
Hi everyone,
here's the problem I have with my Alternator.
When I start the car at the morning, after a night without using it, the alternator is crying, like 'hiiiiiiii', I have to go over 3.5krpm to stop this.
I change it once, and change the battery (now I'm running an Odyssey PC680), and it still doing this.
Sometimes, it doesn't, I don't know why.
When I control the tension with a multimeter, when it makes this noise, the tension is about 11.5v, over 3.5krpm, it goes naturally to 13.5v.
It makes the noise also when i put on all the big tension consummer, like lights, warning, fog light, and rear defrost.
Do you guys had this sort of problem, or an idea of what it is?
the only thing which is different from OEM, is the pulley (ebay lightweight one), I don't know if there's a relation with it.
All my belts are brand new, OEM crank pulley, the tension of belts are OK.
Thank you.
