My alarm is stuck on
the_jay
Car: 1993 Infiniti J30
My car is used and only came with the key to start it and not a keyless remote. Yesterday I locked the door with the key and when I went to open it the alarm went off! I pulled out the 75 amp main fuse and was able the start the car and drive it home (albeit with no lights or indicators).
I see on ebay I can get a used remote for the j30 and should be able to program it to my car, is this correct?
I have unhooked the main battery since I'm out for the day in the hopes the alarm will "forget" that I set it off and the drain in the car's circuits will cancel the alarm until I can get that key from eBay.
Is disconnecting the battery going to work? I read something else about grounding an orange wire under the drivers dash.
EriCCirE
Turn key in either drivers door, or passengers door outside key lock to disable :)
suicide commando
Car: 1993 infiniti j30
Same thing happened to me when I bought my used j30. I unlocked my passenger side the opened it and the alarm went off. So I walked to the driver side and unlocked it and the alarm turned off. Ii is also a good idea to get a remote so I bought one off eBay and it works fine.
the_jay
Ordered my replacement remote and turning left/right worked fine. Thanks.
