Ok, so I bought the car and airbag light was on. I pulled the airbag off to find out that the spiral cable piece with the wires had been cracked and the airbag was not plugged in. I got the new piece and plugged in the airbag. But the airbag light is still on.
I researched this issue and read:
Quote »
Key on, depress driver side pin 7 times within 5 seconds to scan codes.
Same procedure to clear codes.
You could at least gotten off your lazy *** and searched."
[/quote]Then I read:
Quote »
"Resetting a blinking airbag light.
First of all, while this can be attributable to a bad air bag sensor, it's best to run this past a dealer first.
If you're certain it's not an airbag issue, and you simply want to reset the light (after servicing the airbags or dash)...
Open driver door
Get in
Shut door
Turn ignition to the on position (all the way, but not to start car)
Open door
Reach down with your left hand
Press the door ajar sensor button thing (7) times
Shut door
Start your car.....
This should reset the airbag lamp."
[/quote]Then I read this:
Quote »"hey guys i wanted to add my .03 if you don't mind. i just reset my airbag light. you turn the key on, press the button 5 times within 7 seconds, then press it one more time after 7 seconds. this puts you in the mode where it gives your code, i.e. the series of blinks are intermittant and timed (you can look up these times and their meanings in the fsm). after that turn it off, turn it back on and do the 5 times before 7 thing and press it once more and the light should be gone. turn it on and off again, then your light should only be on for 5 seconds and should be gone for good. given that you fixed what was wrong and such."[/quote]Tried it, but I couldnt get it to clear. Which step is correct?
Is there something I am doing wrong. I pushed the door button very fast to try and it still wouldn't work. Do you have to time it right or something? Does the door open or closed matter?
I think I got it to go into diagnostics mode. After pushing the button 7 times the light blinked one long blink followed by two short blinks and then it repeated. This is as far as I got. I turned the key off and tried it again and the code did not clear. Any ideas guys?
Thanks,
Chris
