darkforcejackal »
https://forums.nicoclub.com/darkforcejackal-u12107.html
Sun Jan 28, 2007 3:35 pm
babowc -- We routed the wires from the wideband sensor away from the exhaust and transmission as best as we could, and ziptied the harness on the way up into the engine bay to one of the solid power steering lines for support. Then, we ran the rest up and through the firewall, ziptying the excess into a bundle in the corner of the engine bay. I made sure to have the sensor mounted before the cat, as per the manual.
WDRacing -- You're a genious; good point - I had noticed the slight delay and had taken note...but now I realize why it's there!
xiongbs13 -- My factory/narrowband O2 sensor is still in place on the downpipe, close the manifold/turbo - so emissions won't be affected at all.
GEO -- The reason I did it the way I did was because the manual insisted on the sensor being at LEAST 36 inches from the turbo, i'm guessing mine is somewhere around 45" away, so I guess I just kind of went "by the book" on this one. It's supposed to help avoid burning the sensor thus extending it's life.
