loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Sep 07, 2009 11:26 am
Ensure the evaporator drain line is not clogged. After replacing the cabin air filter, spray BG Frigi-Fresh (or Ozium) into the AC inlet while in Fresh Air mode and MAX COOL. Switch between MAX COOL and MAX HEAT for a couple of minutes and spray Frigi-Fresh. The nasty odor should go away.
If odor persisted, you may need Einzett Klima Cleaner (1z-usa,com) for the evaporator. If there is a screen behind the air vent, you may have to drill a hole on the air duct close to the evaporator to apply the cleaner.
To avoid nasty odor in the future, replace cabin filter regularly, use Fresh Air mode as much as possible and switch to ECON mode on the last few minutes of your drive to allow frost/condensation to drain from your evaporator.
