My 98 Q45 has been sitting.
CatQ45
Car: 98 Q45
Hello everyone,
I have a 98 ~ Q45. That has been sitting for over a year now. It's been sitting in real hot Climate weather.
The dealer informed me that all I needed are: •Hoses •Belts •Rear and Front Brakes•Antenna for the Radio
Do I need to also replace the?: 1. Replace front wheel bearing4.Replace Brake Pads and Discs5.Replace Brake Lines and Cables6.Is it a Must to replace the Thermostat 30k
Can someone please tell me what are the names of those belt?
slybydesignq45t
Car: City Bus
All the fluids, if you plan on putter her back on the road.
I'm not sure you need wheel bearings unless there's play in the wheel or vibration going down the road. I'm sure they showed you the lateral movement in the wheel?
What happened to your antenna?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Accessory drive belts are easily visible, so you can see if they are cracking.
Has the dealer actually seen the car, or is this a WAG to plunder your posckets?
Wlecome to NICO!
NightRiderQ45
Car: 1998 Infiniti Q45
To answer you question about the belts, they are A/C, Alternator, PS, and water pump.
