Epod »
https://forums.nicoclub.com/epod-u35279.html
Sat Jun 06, 2009 2:14 pm
I don't know the answer to your question, but there was a TSB (Technical Service Bulletin) regarding *some* alternators on 1997 and 1998 Qs. If your Q is one of the ones covered on the TSB, and if you've still got the factory alternator, then I believe that Infiniti will replace it for free.
If you flail around with the search function here, I think you'll find the details, or you could email Infiniti USA with your VIN and ask if your Q is covered, and if their records suggest that they haven't already replaced your alternator.
Alternately, you could ask your local dealer to print a service history for your car...which you'll want to do sooner or later anyway, since it will have other info about other history. If you go to the dealer, you might want to find the details of the TSB here first...I think the TSB came out around 2002 (?), so the service writers have probably forgotten about it by now.
