This is the project car. Its a Standard 1972 Beetle.This is my stock 1600cc, only mods done to it right now is the standard header w/ J tubes and a single glasspack
http://i253.photobucket.com/al...1.jpg
http://i253.photobucket.com/al...0.jpg
http://i253.photobucket.com/al...1.jpgthe 15x4.5" rims with 195/60/15'shttp://i253.photobucket.com/al...3.jpg
After its rolling and on the road, eventually it will have the front axle beam narrowed 4" and with adjusters (allowing me to lower it 3") along with 2.5" dropped spindles.The rear the torsions just require some turning to lower it (free, dont gotta buy anything).I want to get the drums drilled for 4-100 bolt pattern.Add sway bars to front and rear.Then motor wise Im goin to bore an maybe stroke it to a 1915cc. 94mmx69mm with some nicely done heads, mild cam, 1.4:1 rockers, 48IDA carbs, merged header with muffler, and a hi po ignition system.Im wanting 180hp or close, for your info, thats between STOCK Mustang GT and Corvette Z06 status in the 1/4 mile range.Friend has one running that same motor runnin 12's at 106 mph
Some ideas I have rim wisehttp://i253.photobucket.com/al...6.jpgThe wheels on my Sentrahttp://i253.photobucket.com/al...2.jpgor the new Axis Racer X, 15x7 up front, 15x8 in rear, with the stretched tire look
