Elisha »
https://forums.nicoclub.com/elisha-u25283.html
Fri Mar 04, 2005 8:20 pm
so i took my J30 into Midas today for a transmission flush.......i took my own mobil 1 ATF as well.i had some previous idle problems......loss of power and acceleration as well and vibrations.they recommended me to change my plugs and it would solve my problems.so i did. changed all 6 of them and the problem was still there.....so they kinda felt bad cause the problem was still there and tried everything to figure out what was wrong. from coils to injectors and ran all sorts of diagnostics on the engine.apparently cylinder 2 and 6 were not getting power. finally they asked me if i wanted to do the computer diagnostic and i said why not.
so guess what??? they pulled out the ECU and it was corroded from the inside.
thats said alot right there. so they priced me an ecu from the dealer and Infiniti wanted about $1,700 and it was gonne be from Japan.so they called a salvage yard in Quebec and luckily they had an ECU for a 93 J30. what a coincidence.they wanted $450 so i said why not and ordered it in.but i'm waiting till the next paycheck to get it installed. enough spent on one day.
Midas was kind enough only to charge me for 2 hours of labour. for plugs and transmission flush. all diagnostics were performed for free cause: 1. they felt bad and 2. for their own knowledge.Four guys were working on my car to figure it out.
more than i can say for the fellows an Infiniti that give me no information whatsoever and see me as a sucker whenever i walk in the door and over charge me every single time.
anyone have any thought, comments, concerns?
