My 92 Q45 smells like eggs and gas
IGETBUSY
Car: 1992 INFINITY Q45
My 92 Q45 smells like eggs and gas when i drive it and makes a strange noise when I reach 45 mph. Any ideas on what could be going wrong. I have a 120,000 miles on it. Is this common?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No, but we really don't know much about the "Infinity" Q45 model here.
In case you are actually driving a G50, how about a little maintenance history? Do you use Tier 1 Premium grade gasoline only?
Be sure to read your trunk the next time you are back there.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I take it you don't know much about cars, well you have two choices: learn or find another car.
But I would have to say that your running rich, do you see any black smoke at wide open throttle?
If so then you need to check the MAF connector, board and screen and clean all three if necessary.
Start by reading this: http://Nicoclub.com/FSM/Q45.
Make sure the chain guides are metal and not plastic otherwise don't start the car till there done.
Welcome to NICO.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Rotten egg smell is usually a sign of a bad catalytic converter. A stinky cat may also be a sign of other underlying issues.
Can you describe the weird noise?
qship96
Car: 1996 Infiniti Q45
Sounds like you need a BG exhaust flush machine service !!!! Dont just drain and fill the exhaust, or use Andys method!!!!!
Johnny Rocket
Mine smells like HAm & Eggs
goody90q45
Car: 1992 Infiniti Q45 (sold)
When the ethanol mixture gets raised to 15% your exhaust will smell like burnt corn muffins.
MR. Q
It could be your vapor canister.
