benzydad »
https://forums.nicoclub.com/benzydad-u31265.html
Fri Aug 19, 2005 5:25 am
Hello members. I have 92 240sx se, with manual transmission. It has about 135000miles on odometer. I've got it recently from my friend. It's been running well till today. The problem start after I cleaned up the battery terminals. I saw quite dirty battery terminal. So I decided to wirebrush it. After that, I run the car, it started right away as usual. Then I ran it for about 5 min (just idle) and shut it off. Then after about an hour later, I started the car but the car won't start. So I though it might be the battery. So I tried to jump start it. I waited about couple of minuites to be charged. Then started again, it won't work. Tried several time without success. Checked the fusebox(in the engine room) and found nothing is blown.
When I turn the key, I heard click at the on position, then heard another click when I turn further to send signal to starter. I think it is the click sound from the relays (Is that right?). I'm now suspicious about the starter assembly. But before I remove and inspect it, is there easier way to figure out faulty starter? I read some articles about this but I don't know exactly what to start with.
If there is any pictures or drawings, that will help me understand much easier. Thank you for reading and hope you can help me. I appreciate any advise.
