ok first things first, it is not the single cam, but the ka24de twin cam. ok so i bought the car and it wouldnt even turn over but then i moved a vaccum fuse over to a missing ignition fuse and it began to turn over but didnt start. i then replaced the oil, readjusted both cams (they were not in proper positions), checked for spark (weak), fixed the distributor (180 out), and re-tensioned the timing, and put sea foam in the tank (gas is about 5 months old). there are some lose or broken wiresand a few plugs without the other ends do to power steering, turn signals, and i believe power brakes were removed.
there is aslo so an electrical ground that has nowhere to go (idk if thats from the original motor or not). there is a set of wires that have 3 wires that are cut, a red, orange, and yellow wire. i believe the yellow wire goes to what i think is the oil sensor but the others i cant find another end for them. i need to sell this car soon but it has to run first, any tips on what to fix first?
