nsrZ32 wrote:Welcome to NICO! Damn good looking Z car you've got there
As for the mods....list them up.
Mods-Motor Rebuilt-Forged pistons (with stock rods and new stock bearings)-JWT .272 degree Mild Cams-Stage 1 headwork-TT injectors-pressure cleaned and honed upper and lower intake-EGR bypassed-heater hoses under the upper intake removed-Koyo radiator-Z1 Aluminum radiator hose-AMZ underdrive pulley-JWT tuned ECU-New engine and battery harness-JWT intake-AMZ ported stainless steel headers-SZ high flow cats-3.5 inch single outlet Greddy Super Dragger Exhaust
-Excedy S2 clutch-RPS lightweight flywheel-Nismo transmission Mount-Z1 1 piece driveshaft
-R33 Skyline drilled front rotors (atleast came off of one)-Brembo slotted and drilled rear rotors-Axxis semi-metallic pads-rebuilt and painted calipers-17X8 MB Weapon wheels with 235/45R-17 Kumho Ecsta tires (for street use)
-no name front strut tower brace-Energy differential bushings-Energy sway bar bushings(more suspension work on the way)
