My 89 240sx is throwing a EGR code
scottsi
how woudl i go about fixing this? is there a sensor? or is the valve just sticky?
scottsi
i searched and i cant find anything on clearing the check engine light, i just want to clear it so i can smog (im in ca) and then i can swap in a RB series engine.
ricebike
2002 Quest
2005 Altima
http://www.240sx.org faqs?
mebbe here as well?zeromain?id=110
WhiteKnight
Car: Nissan 240SX
scottsi wrote:i searched and i cant find anything on clearing the check engine light, i just want to clear it so i can smog (im in ca) and then i can swap in a RB series engine.
Another thread said you can ground the temp wire
locoluna825
Car: 90 240sx coupe
there's a lot of stuff to check when you throw a egr light could be BBT valve, egr Valve, solenoid switch gone bad, bad charcoal canister, a hose may have fallen off, a hose may be Hooked up wrong. BTW most smog guys can tell if you've cleared your engine light or not, dudes are like gurus or sumthin. your best bet is to ask a smog guy they went to school to learn about egr systems its part of the smog system on cars.
