evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Mar 17, 2009 4:27 am
if you are concerened about grounding have a look at the battery cables, are they in good condition? nto cracked or some hack job replacement end applied over stock corroded wires? the ground wire should be bolted to the firewall near the battery, and then to the engine and trans at one fo the trans mounting bolts, there are a few wires grounded to the side of the intake lenum, these groudn the ecu, there si also a chassis ground near the taill lights and one up front near the lh headlightIIRC these are for the lighting circuits
