random:
racer parts wholesales 24 row oil cooler kit with mocal thermostat
full autometer guages minus speed hut tach and speedo(ditching stock guages)
haltech platinum(old style but im in the process of wiring it for standalone)
haltech boost control solenoid
haltech dual wideband
dynosty dual wideband gauge
nrg quick release and hub
personal neo grinata leather steering wheel
twm short shifter
cheepo 1 lb shift knob
boosted performance oil catch can
tsw interlaggos 18x10.5 all 4 corners, 285/30/18 in front(general exclaims need to replace with toyo r888's) 305/35/18 rear
engine:
kinetix intake manifold
04 mustang TB with lokar throttle cable(gets tps voltage from pedal sensor)
bc titanium springs and retainers
ports and cams stock
wossner 8:1 pistons
pauter rods
acl hx series bearings
cosworth oil control baffle
boosted performance mid mount turbo kit with precison 6765 cea and heat wrapped y pipe
meagan ceramic coated and heat wrapped headers
dynosty solid motor mounts
dynosty stopper style head gasket
l19 head studs
arp main studs
both main and rod clearances .0035 both compression rings have .0030 end gaps
straight pipe exhuast
jwt flywheel and southbend feramic full face(being replaced by custom southbend 6 puck)
fuel system(old)
walbro 255 feeding Integrated engineering surge tank
dual bosch 044's in the surge tank
cjm fuel rails
precision 1200 cc injectors
aeromotive a1000 fpr
all stainless line, -6an feeding surge tank, dual -8 an feeding rails, -6an return, and -4 an overflow from surge tank to fuel tank
custom direct port meth kit with 3 gph nozzles per runner.
newest dyno, ignore torque the dyno couldnt pick up the rpm signal so i had to calculate off of tires, gearing and speed(tires at the time where 285/30/18 in the rear)
http://www.youtube.com/watch?v=5-TDZQxAP_o
first dyno still needed tuned
http://www.youtube.com/watch?v=MPktIxZOZO4
