my 350z started smoking on the freeway
Nissan 350z / Nissan 370z general community discussion forum
bmike818
Car: 2007 Z
So i was on my way home tonight...i looked back in my rearview mirror. I notice I am trailing grey smoke... i made it home, upon turning off my ebnine in the garage I notice a splashing sound....oil is leaking all over my garage..its like theres a hole underneath the engine letting the oil out..I have no engine warning lights that went off-but I know there is a problem. I started the engine-alas no oil pressure I hope I did not do permanent damage to my engine( iwas running full synthetic) when an engine is out of oil, will it still smoke? or is the smoke coming from the oil hitting the exhaust? I cant take the car in until Monday. Help to anybody that knows what is going on? I had an oil change about two weeks ago. If it was a loose oil filter it should have happened sooner. My garage is a mess and my car is out of comission
bmike818
Car: 2007 Z
alas it was a missing drain plug that caused all this. DO NOT TAKE YOUR CAR TO A JIFFY LUBE-they did not install my drain plug securely..I hope I did not do any engine damage...i shut off the car before the car was completely out of oil
cant belive it...even franchise owned service stations suck arse (JIFFY LUBE YOU SUCK)
PerfectApex
Car: 2007 Grand Touring Coupe 350Z & 1999 Viper GTS-R (700hp)
The smoking is probably coming from leakage around a hot area and more than likely the exhaust. You mention an oil change recently and I hope this is not the culprit but I bet it is. It is easy for so called techs to not replace the drain plug or filter correctly (cross threading) and causing the oil to leak out rapidly when it becomes hot. If this is the case and the dealer did it, they will have to replace the engine. If you took it to one of those lube joints it can become a painful lawsuit. Keep us informed and hope you come out of this ok. Well, as soon as I posted this I saw your own reply and I was right. Jiffy Lube has always had a bad rap for selling crap for parts you dont need. There was recently a video on them on national TV out in the LA area for chargeing customers for parts but never installing them. Under cover TV aired it months ago. Good luck with it.
flyguy2618
Car: 06 nissan 350Z
Im sorry man i hope everything ends up working out, keep us updated.
07 350z
Car: 07 350z
This is the reason that I do all my own oil changes. Years ago my neighbor expereinced the same situation and I decided to do all my own oil changes from that moment on. I know that must have been a nightmare to see all the oil coming out. Good luck on this.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Wow... Sue them!!!!!
Have it towed back to them, get the drain plug from them, and make sure they pay you....
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
Thats just another reason to change your own oil. Hope your car is ok.
simplewon
Car: 2004 black roadster
Jiffy is a large company and will replace the engine had it been damaged, they did me this way on a company car years ago. Good deal on no damage. Mine gets the lube from the dealer. Is as cheap as the minute lube places and the large rubber cover under the engine can pose a problem to the quick lubes.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
bmike818 wrote:alas it was a missing drain plug that caused all this. DO NOT TAKE YOUR CAR TO A JIFFY LUBE-they did not install my drain plug securely..I hope I did not do any engine damage...i shut off the car before the car was completely out of oil
Some punk kid that changed your oil probably did it on purpose, or impacted it to work faster and cross threaded it or even stripped clean out. I don't take anything to anyone but NTB and only because i have close friends that work at 3 different stores within a mile radius of my home, but no one touches the Z but me, Full synthetic Mobil1. Thats the way to go......
rmezz13
Also check your transmission fluid, a lot of noobies drain some of the transmission fluid because they are retarded and don't know what an oil pan looks like. Those places hire anyone! If you can drive, they hire you, or if you at least have a bus pass......
Roadzilla
Car: 2003 350Z Touring, 2008 Lexus RX 400h
I wholeheartedly agree!!! I had the same thing happen at a Santa Barbara, CA Jiffy Lube. Luckily, my oil light came on as I was pulling away from the parking lot and I went right back in. I NEVER, EVER go to JiffyLube. Crappy lube! I always go to the dealership where I know the service guys.
Sorry it happened to you. Please post the end result if you do confront them with this. I would be PISSED!
quietkilla6
Car: 2004 350z
i bought a set of volks and not only did the instalation shop scratch my lip they didnt put my rays valve stem back on they infact didnt even put a valve stem on one wheel
Return to “350z / 370z Discussion”
