1990_Z_Dude wrote:Could it be a possibility that its the fuel pump? It sounds like it cuts in and out, but that may be because its not getting enough fuel before it reaches the pump...DAMN IT! Any help would be great! Thanks a million.
If it was the fuel pump, hitting the pedal wouldn't help.
Anthonysflying wrote:Im not sure about the z32 but here is a quick check list in no particular order.
PCVEGR MAFAnd the dirty air filter that probably caused the problem
I have never known a dirty air filter to cause any serious problems... maybe just cause it to be a little sluggish. It would have to be SERIOUSLY blocked to cause problems. Same with EGR. PCV is pretty rare, and wouldn't cause a problem like this... and if a MAF is acting wierd... all bets are off, anything can happen.
