My 300zx stalls after running for 10 minutes!
dmatmon
Car: 1985 300zx 2+2
I was driving comfortably and stopped at a light. The Z stalled at the light, I started it again, it ran 1/4 mile, then stalled again...
My mechanic has eliminated the following as culprits:
Igniter...fuel pump....relay...mass flow sensor
He said that it seems to shut down when it gets hot (?)
CAN SOMEONE PLEASE HELP!!!! Thanks
KillaZNA
Car: 1990 NA z32
Time to check the temp sensor. Its the connector that's in front of the engine on a radiator hose.
dmatmon
Car: 1985 300zx 2+2
Thanks a lot! I'm going to check it out now!! I'll let you now ! Thanks again!
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Yeah def. check the temp sensor it does all kinds of weird things when not working right.
Also, have you actually pulled codes yet?
http://www.nicoclub.com/archives/nissan ... ostic.html
dmatmon
Car: 1985 300zx 2+2
Thanks all you guys for your input...found out it was the computer shutting down the fuel pump!! Thanks again...appreciate all the info!!!
nissanfreak12
Car: 92 300zx 2+2 TT
How did you come to that conclusion?
Fuel temp sensor is another thing to check as to why its shutting down.
dmatmon
Car: 1985 300zx 2+2
Not being a mechanic, I'm at their mercy...so that was his conclusion and it works GREAT!
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
How did he say he fixed it and how much did he charge? I'm sensing a rusty pole on this one...
dmatmon
Car: 1985 300zx 2+2
He changed the fuel pump and the computer...came to $500...complete...I'm SURE if I was more mechanically inclined, I could've done better!! Maybe in my next life!! Thanks again!!
