Front bumper and hood are easy.for the rear, first lay a insert (pre lay) where the license plate is.trim it out, then lay the vinyl over the bumper and tack down just the face of the rear bumper , then when you get the the corner, evenly heat the vinyl so it gets loose, once you get it nice and loose stretch it right over the corner and try to lay down flat all in one pull. After you get both sides pulled around work your way up then do the bottom last. When you vinyl to the bottom of the bumper the work it stretch it into where you put your pre lay. I would recommend you put a little bit of primer along the sides where the rear bumper dips into the license plate are to secure, since that's where it's going to be stretched the most...
Hope this helps. Post some pics here when it's done or if there's something you run into. Good luck!
