85toycrawler wrote:--------------------------------------------------------------------------------
Update. Realizing I didn't have power to that red and white wire, I decided to do a little experiment. I jumped that wire straight to the battery with a long wire. Not only did I re-gain power to my fuel pump and such, the tach, oil pressure gauge, and temp gauge all started working. I will check the speedo later when I drive it. I also have more dash lights... (apparently I'm low on windshield washer fluid)
So my question is, how bad of an idea is it to run that wire permanently? With a fuseable link and relay.... I know it's not the best way to do it, but I'm not great with electrical and I cannot afford to take it to a shop at the moment.
Going to check the lights now, hopefully they are good too.
It's bad, find out what that wire goes to and fix the connection. This will take time, but it's the right way to do it.
Below is the holy grail of wiring diagrams:
http://www.ttxtz.com/tech/lee/
Fearspect wrote:For what you paid, and what you will get (for a minimal cost, but a lot of time), you may just consider straight up cutting it all out and throwing in new harnesses...
If you do go that route, might as well throw in a 95+ harness (and CAS) to support the new style fuel injectors.
Different harness. What he's describing is a chassis harness, no the EFI/ECCS harness. But I agree if changing that harness to go to the 1995 variant.
