my 2jz kouki
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
edward644
Car: nissan 240sx kouki 2jzgte swap
So i was just waiting to sell some of the cars that i had, to start my project. So i kept thinking hmmm Rb26 or 2jz. well i made my mind up and when and got this last week. I know its not the nissan family but not many ppl have them around here, 2jz swap. i been getting parts here and there and its about done. i am only missing 2 parts. I when all out and i just spend about $4,000 on the swap. That leaves me with extra money for up grades. hahah
Had to power wash the crap of it!!!HAHA i am under the car!!!ok its the first one and still working on the little things. i got the intercooler all done. so dose not look like the one in the vid any more.
get the shifter housing and the drive shaft.. other then that just go over the little things. i have to extend my ecu wires and thats it. here is another vid.
[/QUOTE]
edward644
any one know how far to extend the shifter? really need to know this asap
sikgtr
Car: R33 gtr S14 2jz 3.4L 91mm Pro Mod v160
i think its about 3inches
edward644
sikgtr wrote:i think its about 3inches
i cant do i thinks. cuz droping the engine is not just a walk in the park.
3in form were to were???
sikgtr
edward644
sikgtr wrote:
man bro your a life saver... thanks a milion
edward644
so i ran into some cheap brakes... hmm maybe some evo brakes hahah
here is how its going to look on 18" haha
just some pics of how its going to look..
this are the rear.
the front....
the ones all the way to the left are cobra rotors and then s14 and evocobra vs s14 haha evo's are still bigger then both
styc
is that the stock cross member?
edward644
styc wrote:is that the stock cross member?
yes its the stock one. i am using TDF mounts
cashed240
Car: 95 se , 91 se hatch
what did you do about the power steering hoses?
NightRyderNy
He I was wondering where you got your motor from and also where you got your TDF mounts from?
Great swap and good luck with the car.
mikesloud
Car: turbos and SPL world champ
where did you get your mounts ? do you have any wiring info for s14 swap? i really need some help on what is needed to power up and waht plugs needed under hood on s14 harness. tech 2 is 5 weeks behind on harness work. And i really want to do it and learn it but need a little guidance thanks for help as so many people post , just trash talk instead of help. thanks for any help out there.
cobra tom
Car: 2003 turbo cobra
Who is TFD?
0range_Kouki24O
Car: s13 coupe and s14 sr20det w/2.3 stroker
im doing the same swap except with a 1j but basically the same motor do i need the shifter extension or is there a diffrent alternative
sikgtr
you need the shifter extension
turbor1
any more info on these "tfd" mounts? never heard of them, nice swap though. should run like a champ
cole d
Car: 93 S13 conv
(TDF) Turbo Dave Fabrications he works at Mainstream Performance in Atlanta
cole d
Car: 93 S13 conv
Is it possible to source this swap with engine and transmission together or is always seperate pieces.
0range_Kouki24O
is there any modifications for the lower engine harness ??? also, what did you do for your fuel lines??
RCA
cole d wrote:Is it possible to source this swap with engine and transmission together or is always seperate pieces.
Yes.
You can buy them together or separate.
edward644
sorry i forgot i posted my car here. i got some update pics
edward644
here is what i am about to put on it now
well i am about to be ready to drop my newer!!! turbo in my car. stupid twin had to take a s***. haha hope to be pushing 600whp
76trim t4
Return to “Hybrids”
