Either is possible but make sure there are no wiring problems first.SullivanRacing06 wrote:so i got home around 2 last night from orlando with my girl, let her go to sleep so i go out to the shop and decided to take agnus (my 240) for a quick cruise up to the gas station, on my way back i notice my oil pressure gauge start to move up and down a lil bit, then it drops to 0! so what are the chances that my brand new N1 oil pump f*&kd up on me, or the crank collar that top hat installed for me twisted on the crank? any suggs would be greatly appt!!!!! now im sitting at my computer feeling
x2 on that. Did the little orange warning light below the gauge come on too? It uses a separate on/off sensor. Do you guys even have those on 240's?Booztd 3 wrote:I'd check/replace the sensor before getting to worked up.
The RB26 and Z32 oil pressure sensors are the same, and extremely prone to failure. Mine failed completely a few months back (always reads 0 now) and before failing completely it would randomly drop to 0, I verified pressure was good by installing a Defi pressure gauge.
there is a dummy warning light on 240s, just no pressure gauge. the sender looks the same too, but it's 1 wire instead of 2. depends if he wired it or not.Cjmartz2k wrote:
it has no oil pressure at all, im using a stock gtr oil pan that i cut the diff off of, still has the stock baffles in, using 6qts of oilRare_f8 wrote:If you start the engine now do you have oil pressure? If no then check out the wiring, if it's ok, then time to yank the front out.
But if you have pressure still...
sounds like cavitation in the oil pump. Which would explain why the oil gauge was weaving, then the drop to zero... and then oil pressure returns.
I seen this happen on these motors when the oil is being forced away from the pick up. The foamy oil is then low enough for the pump to suck it in, and since the oil pump is under a vacuum tiny bubbles expand until a complete cavitation. Soon as any tiny bubbles enter the system, means the pump is pumping less oil, exactly what your gauge was reading through weaving at different levels, then 0 at complete cavitation.
Do you have the stock oil pan and baffles on still by chance?
I ask because it's been more and more the case that the oil pick up has not been baffled properly.
If so then modifications like extending the pick-up... like welding a tube like the Nismo Z-tune GTR. Tomei sells a trap door baffle to fit stock pan. Or a larger capcity oil pan. Then there's always dry $ump.
And on the side note... Besure you are putting the right amount of oil in your engine.
Modified by Rare_f8 at 11:59 AM 6/15/2008
I actually was waiting for your response. I was going to mention N1 are known to crap out, you are better off to get a Nismo, Trust, Jun, or Tomei pump... it's expensive.. but it's insurance...SullivanRacing06 wrote:it has no oil pressure at all, im using a stock gtr oil pan that i cut the diff off of, still has the stock baffles in, using 6qts of oil
email me, [email protected]SullivanRacing06 wrote:u have a jun in stock? how much and what kind of warranty can u give me? this pump going to screw up on me?
So I wasn't supposed to open up the collar with a ball hone then hammer it on? I did tap it and put an 8/32 screw in there to hold it. I splurged on stainless.l0nestar wrote:Exactly.
Pull the motor and begin tearing it down to find the culprit(s)!
If you pull the plugs, can you rotate the crank by hand / with a breaker-bar? Can you get it to turn over at all? Can you 'blip' the starter a few times to attempt to build oil pressure?
Also, crank collars should be heated & pressed on, then tightened with the grub-screw, then polished smooth, just to prevent this. Or better yet, welded on!
Evan
all but perfect? **** i wish it was any where near perfectdwnshfter wrote:damn, looks like your **** will be all but perfect! pics?
damm i wish top hat actually insatlled one for me instead of fuc!in me for the money, now their tryin to make me out ike a idiot screw top hat f u mike , name thp240z4u wrote:
Yeah totally!
