My 240sx with rb inside
danielmcn
I had a 90 240sx with a rb20 in it and loved it. I ended up trading for a 431hp eg hatch, big mistake. The day I traded it the transmission messed up, and I never drove it again. So, I traded that for my 92 coupe, had a sr20 s13 blacktop in it. Ran like s*** when I got it, but I tweaked it and got it running really good. I was unimpressed with that though, so I traded swaps with a guy out of winston salem nc. Long story short, he f*** me. I got a r31 rb20 eccs redtop :cry: . well I did some research and found that the blocks are the same and some say its a little stronger. I also found out that you can put r32 ecu and harness on the redtops and bring them up to the power of the r32 silver top. I set out to do this. I ended up getting a deal on a head with bent valves, intake, and everything bolted to both ($80). So now I need valves, but those things are way to high. In looking I found that the r31 and r32 use the same valves. I pull the valves out of the r31 head, and striped the r32 head down. I dropped the r32 head and r31 valves off the get a 3 angle and a good .040 shaved off the head. Why shave the head? I am trying to get into the 9s compression wise. To help spool this hx35(8blade) I have for it. I have the head back and am going through it with a dia grinder doing some port work, along with stem seals and stuff like that. I got the ex side almost done and pulled the stem seals out. Now on to the pics....
This is what I ended up with.
At least it has a Greddy timing belt.
Stock rb25 turbo.....
Here is the car when I got it, and put the coilovers on it.
before the front coilovers
after the fronts are on.
here is a pic of the motor.
Pulling it all apart.
I am pleased that the cylinder walls are not scared up.
this is the latest.
New seats
Exhaust side, I need to touch them up a little.
Start to the intake side, far from finnished.
Unported intake side
I have a full gaskit kit here, and have arps on the way. Looking for about 300 on low (7psi) boost, and trying to get full boost(7psi) at around 32-3500 rpms. I also have a 38mm ex wastegate that will go on too. I have a ton of other parts too.
So what do you guys think so far?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
That a tophat intake manifold on that motor? Your prob going to need more than 7psi to hit 300hp.
danielmcn
I am doing more then just bolting a hx35 on it. I do want close to 4 with high boost, but there are a ton of things that will go into getting that number. I should be in the 9.3-1 range and that will help, the vavle job and port work that I am doing will too. I all so have a set of r31 cams (248in/240ex), the intake cam is a bit bigger on the r31 then the r32. I am all so getting it tuned, and running a topmount manifold with an external 38mm. If I dont see 300hp on 7 I will be damn close.
I am not sure about the manifold brand, I cant see any markings on it and it was on the motor when I got it.
s13rb25detdrifter
Car: 1992 nissan 240sx
rb26dett
That. Head is bad resurfaced do it right man trust me just take your time I have a 26 and im taking my time I wanna do it right
danielmcn
s13rb25detdrifter wrote:That. Head is bad resurfaced do it right man trust me just take your time I have a 26 and im taking my time I wanna do it right
What????
Dude I am taking my time, and the head was resurfaced and is smooth those marks are tooling marks.
This is what I did to the intake splitters. Ports are still dirty and need to be cleaned.
My arps came in and I started replacing the gaskets. I am all so removing the turbo water lines as mine is a oil cooled only. I put the new water pump on too. I just have to do the rear main seal and button up the head.
I need mounts if anyone has any for sale.
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
That's a metal wheel rb25 turbo you have? is it in good condition?
I like that you did all the research and are piecing ur own lil beast together :biggrin: Hope all goes well on your build
danielmcn
TimTurboZ wrote:That's a metal wheel rb25 turbo you have? is it in good condition?
:dblthumb: Thanks, I hope to have it together in the next few weeks.
I no longer have the turbo, but I was informed that it was a later r34 turbo.
