My 240sx w/SR20DET and Silvia conversion
TJ_GT
Car: 1989 240SX Coupe w/silvia conversion and SR20DET
i just got her about 3 weeks ago, still working out some bugs.. my boost controller makes weird noises and doesnt work right and i'm running a 4.6:1 A/F ratio under boost because of a broken Intake Air temp sensor. Before the IATS was broke she dyno'd 306 RWHP at 16psi. So far my upgrades include;S13 SR20DETHKS GT2510 Ballbearing TurboHKS 555cc InjectorsHigh Flow Aluminum Fuel RailHKS Boost ControllerHKS VPCTurboXS RFL BOVWalbro 255 Fuel PumpGReddy/Trust front mount intercooler w/ pipingGReddy/Trust 3" downpipe w/test pipe3" custom Cat Back ExhaustGReddy EmanageNismo Clutch (getting replaced asap)VLSD Diff.
HailtotheSilvia
Car: 93 S13 coupe
[QUOTE=TJ_GT]i just got her about 3 weeks ago, still working out some bugs.. my boost controller makes weird noises and doesnt work right and i'm running a 4.6:1 A/F ratio under boost because of a broken Intake Air temp sensor. Before the IATS was broke she dyno'd 306 RWHP at 16psi. So far my upgrades include;S13 SR20DETHKS GT2510 Ballbearing TurboHKS 555cc InjectorsHigh Flow Aluminum Fuel RailHKS Boost ControllerHKS VPCTurboXS RFL BOVWalbro 255 Fuel PumpGReddy/Trust front mount intercooler w/ pipingGReddy/Trust 3" downpipe w/test pipe3" custom Cat Back ExhaustGReddy EmanageNismo Clutch (getting replaced asap)VLSD Diff. QUOTE]
Correct me if i'm wrong...but how do you make 306 whp at s16 psi with the SMIC?...doesn't make any sense
TheLocust
maybe im lost, but it says he has a Greddy FMIC?
S13240
If you guys look at the third picture you guys will see the fmic. That fmic seems to use the stock smic pipings.
Blown240sx
Car: 1996 240sx
you can run them that way because thats how they are on Honda and Acuras but it doesnt make much sense because of the extra piping but it can be done that way.
TJ_GT
yes its a greddy/trust fmic, but it sux cus both the in and out's are on the same side. i really need to get a bigger one.....
Luke
Weird, looks like a side mount to me, you have any other pics of the FMIC? I'm curious to see.
Also, I don't remember my SR even having an "IATS". And that A/F ratio you listed has to be way wrong, an optimal a/f ratio is something like 12.0:1. (only a wideband o2 sensor can detect a/f like this, if you're is stock, it's not a wideband)
Henry G
someone stole your headlights...
other than that looks good!
TJ_GT
Luke wrote:Weird, looks like a side mount to me, you have any other pics of the FMIC? I'm curious to see.
I dont have a maf, i have a VPC (vein pressure converter) runs off of a MAP and IATS. As far as the A/F its called an exhaust gas analyser...i put it on our dyno at school just so i could run it under boost and get my A/F ratio. and yes its 4.6:1 which is WAY wrong. hence thats why i need a new IATS
But yea i'll take some pics of the intercooler, maybe it is supposed to be a upgrade for the SMIC but it came with the car so.......
Henry G wrote:someone stole your headlights...
LoL yea the car was hit before i got it, need new headlight and fender. Thats why i got it for only $3700
RichthePoser
Car: Starion and WRX
who doesnt love a good beater!
Rich
ETTInnov04
Car: 1989 Nissan 240sx fastback
Is that the way your motorset came or have you collected and put all of those parts on yourself? That so called "FMIC" looks like the GReddy side mount core that was moved to the front, I dont think GReddy would call that a front mount core. I personally wouldn't run that intercooler on that kind of boost or power level for that matter, just not safe. I'm not trying to degrade your project, just trying to make aware of somethings that may give you some trouble in the end. All in all its nice to see your project and see the numbers that you've made.
TJ_GT
the only thing i have put on the car is the BOV, the rest came with it. Not a bad deal for $3700. And yea i do plan to get a different FMIC, something alot bigger....
john 89
Car: SR'd 89 coupe
looks kinda ghetttttttoooooooooo i love it
kota2240
Car: 92 Nissan Coupe W/ CA18ddet
that turbo alone is around 1500.00+ not bad
ETTInnov04
Well hopefully you can treat it better than its previous owner, whats going on in ther is just wrong. Good luck with it and keep us posted
