Man your car is amazing...OutToWinPAHC wrote:The inside of your TB is 3.0732 inches on the 78MM TB, The outer dimesion is what you should be using.
See your 90 thats the size you should be using
Modified by OutToWinPAHC at 6:20 PM 10/18/2007
NICE! You going to the track tonight? Would love to see some 11 second time slips.Blown240sx wrote:Well went to the dyno and we tried MAF no pipe and Pipe and the difference was 4 HP more with the Pipe and Filter on. So I guess like I said the smallest point of the intake will be the limiting factor.
390 whp and 370 ft lb tq
compression is a bit weak so we figure on a fresh motor about 420-430 whp
