NiceLyphe »
https://forums.nicoclub.com/nicelyphe-u151307.html
Sat Feb 27, 2010 2:30 pm
Well, i bought the car down in NJ yesterday for 1k..My plans are to work on it a bit, like a long term project i suppose. It runs fine besides the play in the clutch pedal, and the little pinging sounds from the front area of the car (sounds like if you put a few nuts and bolts in a coffee can and shake it) not so sure what that is. Also the hood hinge support bar area needs to be fixed, need to find a new one of those. Only one bulb is working behind the gauges in the dash..the previous owner put a KM/H cluster in it..Has hood pins on the stock hood because of the hood latch problem which im rly not a fan of the pins..Interiors clean though. Rusting a bit below the driver side door, and the drivers side frame rail =/..definitely gonna have to get that taken care of. We'll see where this ends up. First thing on my list is to figure out that ping noise..
Dented roof..is that panel removable and replaceable??
Modified by NiceLyphe at 4:53 PM 2/27/2010
