My 240sx leak problem
Zell311
Car: s14 SE zenki
i have recently purchased a 1990 nissian 240 sx
this is why im here
my car seams to be leaking a oil/antifreeze mixture it seems to be coming from the head gasket but it cant be sure.
does this seem right due to the mixture?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
intermix is bad, especially if its leaking. Don't run it anymore, your need to replace the headgasket and you should get the head checked / milled if needed by a machine shop.
Drain your oil, see if its green in color or milky looking or smells sweet. Was the exhaust steaming or smoking?
95 zenki
Car: 95 NISSAN 240SX SE -ZENKI
I agree get it fixed asap
Zell311
Car: s14 SE zenki
as soon as we saw it we stopped running it. the oil on the dip stick did not look milky and i didnt notice any steam or smoke from the exhasut... ill keep you posted.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Drain the oil its hard to tell on the dip stick. If it looks like chocolate milk or visibly its intermix. Either from a warped head, blown head gasket, or cracked block.
Zell311
Car: s14 SE zenki
the car seemed to be running fine and as soon as we noticed the leak we shut it off. it seemed to be coming from the headgasket...
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Ok see post two. Pull the head, check decking, have the head checked and milled if needed (60 bucks), replace head gasket, timing chain and gears if you can afford to.
Zell311
Car: s14 SE zenki
okay i have just ordered head bolts head gasket and a timing set....
ill have the car pulled apart shortly...
im hoping the head is not warped, the car seemed to be running fine when we noticed the leak and shut it off immediatly
