goj_cloud wrote:i have a 90 240sx with the 93 twin cam engine in it, it wont start up, the ebgine cranks the fuel pump comes on the spark plugs dont spark for some reason but the spark plugs are fine.
Ignition coil needs to be checked first.. take the wire off the distributor that comes from the coil, lay the wire next to a screw on the valve cover (get it real close) and when you turn the car over, see if it arcs. If it does, repeat the process with each of the wires off your distributor. If you have trouble getting the electrode tips close to something grounded stick a screwdriver up there and see if it arcs from the screwdriver, but dont hold it when you turn the car over please. (it hurts, trust me)
