locoluna825 »
https://forums.nicoclub.com/locoluna825-u93365.html
Sat Sep 19, 2009 2:03 pm
i tried that once any one of my injectors just blew right off the rail. might have been the bad seal install though, don't know for sure though.
someone suggested to keep this from happening, after you have drove the car around, immediately after you ave turned the car off. remove the fuel rail, completely attached, injectors and lines. you can disconnect the harness plugs though. and place a piece of paper under the injectors and let it sit. then check everyone and a while for discolored drops on the paper.
