waxdnuggz »
https://forums.nicoclub.com/waxdnuggz-u213188.html
Sun May 04, 2014 1:21 pm
Check your dis. Set your motor to tdc pull the cap off the rotor should be facing straight forward (towards the radiator). Get a spark tester idk if you have harbor freight around you but I looked at one yesterday for 3$ there. Also check your coil pack. Alot of people forget about those. The only plugs on the motor that will stop the car from running is (1.distributor 2.fuel injectors 3. Coil pack and rely next to it) it'll run with all the other plugs undone just not well. Also make sure the injector plugs aren't mixed up. And make sure that there aren't any vac lines unplugged. Idk if your a smoker but if so or have a buddy do it take off the air box plug the throttle body with a can of spray paint of something and tighten the coupler down and blow smoke into the aicv tube (s shapped one that connects to the intake near the throttle body it goes to a hard metal pipe that runs thru the intake under the runners. If you blow smoke in it and you see any with the throttle body plugged you know you have a leak.
