niemczykj »
https://forums.nicoclub.com/niemczykj-u51224.html
Mon Apr 16, 2007 7:48 pm
i just have a quick question about my 92 240sx....
i just did a ton of head work on the car and i put everything back together, and when i was setting the distributor i used the write up on nicoclub....i set the number 1 piston to TDC and aligned the rotor and plug wire for the that cylinder all perfectly...so i tried to start the car and it wont fire....it has gas and compression and all the plugs and wires give spark....so im assuming my timing is off
i was just checking to see if i should be using the stock 20degree advance timiing, or if the TDC timing that u talked about is supposed to work or not....
also i have platnum plugs and i think it just has 87 octane in now if that helps anything
ThanksJosh
