My 240 with sr20det is only firing on 2 cylinders :(
phroze2001
Car: 1990 240SX with sr20det
I installed an sr20det into a 1990 240sx ive got everything done, i went to start it and it started up rough i pulled the packs off and tested spark and only cylinder 1 and 2 are firing 3 and 4 are dead i first tried swapping coil packs with one that worked and nothing. I then tested the packs for ignition on 12 volt power and they are all getting power i tested them where they get the signal from the ignitor and they were all getting low voltage when cranking the engine over but the 2 that wont fire are getting higher voltages than the 2 that fire. Any help would be greatly appreciated.
InsanityInc
Have you done a compression test, or checked the injectors?
You need compression, fuel and spark to make a cylinder fire. You've checked one, now check the others.
phroze2001
The back 2 arent getting spark at all
phroze2001
To the top for my non running car
slow s13
Car: cars, photo, music
double check your wiring, if your shure its ok. check the ignitor per fsm, and if you extended those wires check them too, then onto using a different ecu.
phroze2001
Would the ignitor stop just two coil packs from giving spark? How should I check the ignitor? Voltmeter? If so what sort of voltage should i see when cranking it over?
phroze2001
echo echo echo
got_boost702
Car: racing, cars, snowboarding
the ignitor will stop just 2 cylinders from firing. This recently happened to me, the ignitor was causing the 3rd cylinder not to fire in my redtop. I dont know how to troubleshoot the ignitor, i would just go to a parts store/junkyard and pickup one of a q45 or which ever one you have on there.
phroze2001
Right on thanks man ,you have instilled hope into my dream lol I just purchased one and am waiting on it to arrive.
boost_creep
Car: 92 sr powered coupe,06 Spec V
i ahd this same promlem a couple months ago...i unplugged the ignitor to check the wiring(both sides)..and when i plugged it back in the car ran fine...did u try this?
phroze2001
I didnt mean to check it like that but yea i pulled the igniter off and checked voltage going to it and plugged it back in and tried it one more time and still notta.
phroze2001
Still waiting on my ignitor shipping from Japan takes forever so I sure hope that was the problem
phroze2001
Runs great now, it was the ignitor
slow s13
great news
