KGB »
https://forums.nicoclub.com/kgb-u78063.html
Wed Feb 06, 2008 10:02 pm
The basics to maintain a running engine were mentioned earlier. I narrow it down to fuel or ignition problem. I doubt its the fuel pump but dont rule it out, could be the ignition coil, inejctors. Check those out. The coil could be tested by pulling the wire off of it and place it just above the head or block, youll be looking for a super white or blue spark. The injectors just take a long screw driver and stick the head of it on the injector you should hear a clicking or ticking. Thats the solenoid. The pump you should hear a buzzing sound before you start the car, just turn the car on dont crank it over, if you do youll cover the sound your looking for with the engine trying to turn over. Hope that helps out
